HP LaserJet 1320 Printer Logo
Posted on Feb 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help!! Triangle with exclamation mark is flashing. What does it mean?
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Feb 07, 2011
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833629
Points
6040
The blinking triangle indicates one of the following: Paper tray is empty, Door open, Paper jam, Misfeed from tray.
To fix it:
Verif that the print cartridge is present and that the print-cartridge door is closed correctly. Verify that media is present in the input tray. Clear any jams and perform paper-path functional checks. To reset the printer after a jam, press the Go button. You might need to clear the error manually, and press the Go button or close the top cover
  • Jason Mgbi Nov 10, 2015
    Tried all your suggestions, but not working for me. :(
1helpful
Doro Flip Phone. I have a red triangle on text messages on my phone?
Question edited for clarity.
Question moved to a better category.
Hello Maurice
questions like this really need to model number of model name. Doro make lots of flip phones. There are various ideas here in the links below.
Remove battery to reset.
Your data usage is exceeded.
The text wasn't sent.
What does an exclamation mark in a red triangle next to a text ...
https://www.cellphones.ca > answers > what-does-it-mea...
Oct 9, 2014 - What does it mean when there is an exclamation mark in a red triangle next to a text message? It shows part of a text when I open it up none ...
Red Exclamation point...... - HTC Droid Incredible - Android ...
https://androidforums.com > ... > HTC Droid Incredible
May 4, 2010 - The red triangle with the exclamation mark is showing up because somewhere in the string of texts you've been sending to this person, you did ...
16 posts · It comes up when sending text messages. Not in the messaging widget, but when you actually ...
W\hat does it mean when i see a red exclamation - Fixya
https://www.fixya.com > Forum > Cell Phones
Nov 20, 2019 - Hello, Normally, the red spot on an envelope in the sent messages means that your text has not been delivered to the destination phone number the text was sent ...
1 answer · 3 votes: Hello, you don't have to be bothered my friend,the red exclamation sign simply indicates that the message is broken along the way which means the message ...
SOLVED: Hi, my husband has a Doro 508,a big red ...
1 answer
Sept 16, 2019
SOLVED: Red triangle appears when text message sent ...
1 answer
May 14, 2015
How do i get rid of red exclamation mark on text ...
1 answer
Aug 21, 2014
What's the red triangle symbol on the android - HTC ...
1 answer
Apr 7, 2011
More results from www.fixya.com
What does the red triangle mean beside my "sent message?
https://forums.androidcentral.com > ask-question > 590...
Oct 5, 2015 · 3 posts · 3 authors
As keyree said, it means the message has not been sent. You should be able to tab the message and hit resend or retry. 10-06-2015 03:50 AM.
Meaning of Exclamation Point in a Triangle - texting ...
Aug 23, 2010
how do i get rid of the red triangle with the exclamation ...
Feb 19, 2016
More results from forums.androidcentral.com Missing: Doro ‎' Must include: Doro
How to remove the triangle with exclamation mark ... - AskingBox
https://www.askingbox.com > question > how-to-remov...
Oct 31, 2013 - The symbol "triangle with exclamation mark" in the status bar is a common symbol for a warning. In your case, that is the data usage warning.
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
What is the warning with a Triangle and exclamation mark inside it
It means "something is wrong". You need to check the messages to find out.
3helpful
What does the triangle with the arrow round it mean and what does the triangle with the exclamation mark in mean please
The triangle with the arrow around it is for the wheel speed sensor. The triangle with the exclamation point is for tire pressure. Low tire pressure would set both of these lights off.
I bought the Polaroid Pogo mobile printer.when I first used it, it worked well.today I tried to use it and it is just not working. My phone seems the picture but the printer gets a red flashing light how...
That depends on which red light is flashing. If the battery light is flashing, that means the battery is exhausted. Fix it by charging the battery.
If the status light is flashing red, that means the paper is jammed. Fix this by opening the paper door and pulling out the media. Full instructions are on page 3 of the manual.
The battery light is the one marked with a battery. The status light is the one marked with an exclamation point inside a triangle.
Feb 12, 2012 • Cameras
1helpful
Flashing orange light with exclamation mark
Just talked to a mate of mine who said its the ASC that has been turned off. I flicked the ASC switch and problem solved.
1helpful
Not printing!
pls open your bakside.and
check there is no any paaper jam in fuser assembly.
k24674
Grand Canyon Tech
Grand Canyon Tech
