Sony Grand WEGA KFE50A10 50" SDTV LCD Projection TV Logo
Posted on Feb 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony LCD projection TV grand wega MOdel KF-E50A10. Encountering problem when TV is switch on. Colour turn bluish and sometimes red. What is the problem if I may know. What parts should be replace. Please advice.
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Feb 07, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
43212
Points
221
Light engine is faulty. try to clean the 3 LCD flexible wire and its connector on your optic block. sometimes this connectors loosen up.
I have sony plasma model KF-E50A10 very dim red light background on screen, blue and red background not working, can yuo please help me to solve this problem.
It sounds as if the LCD matrix has an issue most likely dust. Have you tried cleaning the Matrix itself? I can send you the LCD matrix cleaning instructions for a sony just send me a email at [email protected] and I can send them to you as a pdf file.
Dear sir, The diagnosis by you on the problem is correct. Confirm by sony that we have an optical block and bulb problems. Need to replace both. Where can I get a replacement parts for optical and...
Please confirm tv model number as question shows it is Sony KF-E50A10
Model number info is very important to provide you correct and helpful info.
Thanks.
Hi My sony wega KF-E50A10 Lcd projection TV turn purplish ) Purple) when on . What could be the problem and it is due to lamp that need to replace. Id the part no for the lamp F9308-750-0(XL 2400) from...
michaeltong8,
Your problem is with the TFT panels in the optical engine and is an expensive fix. The KF series has a documented problem with the panels but the time to get relief from Sony has passed. Your only option now is to replace the optical engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, where to get the parts necessary and how to perform the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
My sony kf-42sx300u wnt turn on? the switch flickers green, red + amber? could it b a fault in the switch? louise x
Most common problem is Bad Capacitors they will be vented or puffed up on Top. 2200uf 10v 3300uf 10v 1000uf 16v
1helpful
1helpful
My kf-e50a10 lcd projection tv suddenly just shut off and when i
Check your fans. You have a stuck fan. You may want to call a service center as it is a pain to get to one or two of the fans. Theres 3 or 4 of them.
1helpful
Problem for Sony Grand WEGA KF-42SX300 42 in. LCD TV Only goes from red to amber on led
hello try a factory reset. turn on the tv while holding the reset button on the remote control, press the power button on the tv, the tv will turn itself off and back on again release the reset button
shaun
52"wega sony ,model no. kf-e50a10
most likely the lamp shattered. Very common just replace the lamp
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
