Hi, My salter scales model 9018S SV3R display is reading 'L' I have changed the battery and it is still the same. Any advice on what might be wrong with it would be really appreciated? Many thanks.
I believe you put the wrong batteries in.
This pack of 2 high quality CR2032 batteries are ideal for Salter bathroom scales. Please check that this is the correct battery for your scales. Diamter 20mm, thickness 3.2mm. With long shelf life, these CR2032 batteries are the perfect replacement.
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally.
If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
