RCA F32650 32" TV Logo
Posted on Feb 06, 2011
My RCA F32650 32" TV keeps turning on and off. I
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
2380
Points
33
Hi there! i hope this will help u find the solutiuons:
1. replace the power transistor at the horizontal section of your tv by desoldering . and buy with the same value, the store assistant in your area will do help you replacing the defective part of your tv. Thank You.
My ps3 turns on but no picture
First, how are you connecting? RCA jacks(red yellow white cords) or HDMI? If it's the RCA cords, they were known to develope shorts in the yellow cord that connects to your TV. Just try another cord. They are very cheap, and the cords from all of the other Playstations will work for the PS3. Second, try to do a picture reset on your system. Sometimes, going from HDMI, back to the RCA confuses the system because the RCA connections are NOT detected automatically, HDMI is. To do a picture reset, turn the system on, then push the power button once,(you'll hear a beep) then push and hold the power button until the system shuts off.(you should hear 2 beeps) Then when you turn the system back on, the picture will be reset. ^^ Good luck, and I hope this helps.
2helpful
2answers
I turn it on. It shuts itself off after 1 or 2 seconds.
Ok, well to me It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
1helpful
Rca r56wh78 Keeps coming on and shutting off
If you have no experience with electronics or are not a TV technician or not have the right tools then you will either have to get a tech or find a hobby to entertain youtill you can get it fixed.
The TV shuts doen because of a voltage leak in the power supply or on one of the X or Y video boards. Do not let it continue to cycle as eventually it will die completely and be more costly to repair.
This is not DIY It involves the starter solenoid and the oveload detector trying to shut down to protect itself. it also requires knowledge of circuitry and the use of volateg checkers
Please rate our help to keep the free service online ++++
Thank you for using Fixya
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
2answers
RCA D52W14
That model is famous for bad flybacks that shut the set down and there is no warning they just quit working. If you need further info please let me know.
5helpful
2answers
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
