SOURCE: ks-100 sports watch
Here is the form used to contact lacrosse for a watchband; http://www.lacrossetechnology.com/watchband_form.pdf or you can use; http://www.lacrossetechnology.com/support/contact.php Here is the user guide for your watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf Hope this helps :)
SOURCE: Watch Repair
I would not recommend you attempting to try this at home, because you can severly damage your watch, but if you must, you will find that on the back of your watch relatively near the crown is a dimpled, small metal piece. Take a tweezer and push it in LIGHTLY while pulling out the crown.
SOURCE: I have a Tommy Hilfiger analog watch with date.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to TOMMY HILFIGER watch manuals. Rate me, please
SOURCE: Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Testimonial: "Quick and informative response!"
SOURCE: Looking for a replacement watch band
need a ck celerity watch band, rubber or lether, K7547138, thank you.
