Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
Posted on Feb 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The router is blocking access to one computer asking for a network security key which is apparently different from the password. How do you find the security key?
Rofel Lantican
Level 3:
  • Master 2,632 Answers
  • Posted on Feb 05, 2011
Rofel Lantican
Master
Level 3:
Answers
2632
Questions
Helped
597461
Points
7882
Hi camavery,
If you want to the security key you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security and under Security Mode you can see the Network Key or Passphrase. The Network Key serves as a password on your network to make it secure. You can personalize the Network Key so that you can easily remember it. Then Save the settings.
If this works dont forget to say thanks. Thanks for using Fixya.
Is there an easy way to secure
Welcome to Fixya. If you want to set a password of the network to make it secure you need to access the router page.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security select either Wep, Wpa or WPA2 under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
2helpful
4answers
Just hooked up the router to my pc and put in the install disc that came with it, the Belkin program won't open on my computer and the laptop I'm using shows it as an available wireless connection put...
Welcome to Fixya. If you want to connect to the Belkin Router Wirelessly and it is asking you for a Security Key, all you need to do is to access the router settings page and look for the Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase)
1helpful
My Wii will not connect to my router. I have tried all the routerlogin.net and .com solution attempts. Also the 192.168.1.1 stuff. No luck. Netgear tells me I have to use their support tech at $69.995....
Welcome to Fixya. If you want to connect you Wii to the internet wirelessly first we need to know the settings of your router. Listed below are the steps on how to access your router. You need a working computer connected to the router to access it follwed by the steps on how to connect our Wii.
How to access the Router:
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Now that we have the information needed lets connect your Wii to the internet.
1. Select Wii Settings
2. Then Internet Connection Settings
3. Search for an AP or SSID
4. Input Security Key or Network Key
5. Test the Connection.
Other Suggestion
Did this connection used to work but has suddenly stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii and test for proper response.
The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to. If it is different
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker
Don't forget to say thanks. Thanks for using Fixya
3helpful
2answers
Want to connect wireless printer but i need WEP key so the printer can connect on same wireless connection
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
2answers
How to set my wireless into private ?
You can make the network secure putting a password with it. You need to access the Wireless Settings Page of the router. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is admin and the password is password. Go to the Wireless Settings Page, Under Wireless Security Mode you can select either WEP,WPA or WPA2. Then Personalize your Network Key. The Network Key serves as a password on your network to make it secure.
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
1helpful
2answers
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
How to use the wireless key
Wireless keys are like your secret password. Provided you have a wireless router and wireless devices to access internet - You might want to secure the wireless signals emitted by the router to ensure that your neighbour is not using free internet :-). So all you do is access the router's setup page and under wireless tab enable the wireless security feature.
Wireles security generally of two types
- WEP
- WPA
select the one suits best to your network and save the changes. once you are done with the router - you will now search for wireless network from your computer/s and select the network. The router will now ask you to type the password (the one you eariler entered on the router). Enter the correct password and you will be connected. Now your neighbours can see your network but cannot access it unless you share your password with them.
4helpful
4answers
Laptop keeps asking for security key, when trying to connect wirelessly . i dont know security key
You need to ask whoever set up the wireless router what the security key is. Apparently, who ever setup the router encrypted the wireless network. Any computer wanting access to the wireless network must have the security key initially entered in for access. If it is your own router, you can access the router and change the security key your self in the wireless setup portion.
3answers
Need a network key
Since you want to access the router setup page and get the wireelss security for your laptop you can try this:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
When you're already on the setup page of the router youc an go to Wireless tab and click on Wireless security and there you can find the security key that you need....
If the default password didn't work you need to reset the router by pressing the reset button for 15 seconds so it will be back to its default settings with default password which is admin.
But if you successfully log in to the router page just go to the Wireless tab and there you can find all the wireless settings of your router including the wireless security key...
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
