IF YOUR MACHINE RUNS FINE UNTILL IT GETS TO THE SPIN CYCLE OPEN THE DOOR IF IT'S A TOP LOADER AND TAKE A SMALL SCREW DRIVER YOU WILL SE A HOLE WITH A SWITCH LIKE AREA PUSH DOWN ON THE SWITCH AND SEE IF THE DRUM STARTS TO TURN AND SPIN THIS IS A SAFTEY SWITCH SO THE LID HAS TO BE CLOSED FOR THE SPIN CYCLE TO START. IF IT'S A FRONT LOADER THERE ARE MORE SWITCHES AND SAFTEYS AND WOULD HAVE TO LOOK ON LINE FOR YOUR MODEL
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
