Mine doing the same thing, ND code, so I just replaced my pump, brand new, Installed pump, and turned washer on, 16 minutes later **beep** finger went off "ND" code came on again. What now, I blew out line from pump and drain line going into house no blocks or kinks. Maybe the control clock?
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
