Have new charter cable DVR hooked up to receiver with HDMI cable. When receiver is turned off it turns off the cable box too. How do I get that to stop?
When the DISH Network installed hooked up their DVR, did they connect it via HDMI? If so, then it could be a bad HDMI connection. I would bet they simply bypassed your receiver and went straight to the TV, which is why no audio comes out of your receiver. You can test this by turning on your DVR and TV. If you see picture with your receiver OFF, then they bypassed your receiver. You'll need to hook up and HDMI cable from the DVR into the receiver and then out of the receiver to the TV.
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
I have the same problem. It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video). Video and audio cutout is random and drives the family nuts. I am desperate for a solution.
1.This issue sounds as though the TV connection circuit has an issue. 2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit. 3. This will require some troubleshooting by a qualified tech. 4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV. 5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
