Question about One For All URC-9800 LCD Remote Control
I have a motorola dct700/us cable box but I don't have the remote. The universal remote I have says to turn on the unit and enter the code etc. The problem is that there is no way to turn it on without the remote. Is there a way to turn on the cable box without a remote?
  • 1 more comment
  • dalero Feb 06, 2011
    The remote is an at
  • dalero Feb 08, 2011
    Tried to input 201, it didn't work. I think the cable box must be on for it to work.
  • Anonymous Mar 12, 2014
    set time jaga MO941
  • 1,961 Answers
If you can give the model number of your universal remote, maybe I can give you the code.
Post it here so I can help you further.
Posted on Feb 06, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Feb 06, 2011
    the universal remote you have uses the three digit code 201. Try this code
6ya staff
SOURCE:
How do i program or what are the codes for this remote for sharp tv and a motorila DCT700 cable box
Ask cable Co for a code book or instructions. get a universal remote for the sharp TV
Hope this helps
Feb 19, 2015 | Sharp Televison & Video
Innovage products jumbo universal remote - cable box code
Did you try the above method frim the manual
Dec 26, 2007 | Televison & Video
Motorola DCT700 won't power up.
its working correct... thats sounds normal
now you just need to wake it up. turn it on using the remote supplied by your cabe operator. if anything it may be your remote that isn't working. does a "cbl" light or anything light up on the remote when you press the cable box power button? if not try to find out how to put it in cable mode and try again.
wish i had more info
good luck
Aug 12, 2012 | Arris DCT700 DTV Receiver
DCT700/US - Unable to turn on with remote. Yellow light flashes on then off to brief red light then nothing. Tried removing cables and plugging in to power outlet only, but same result.
it sounds like the box is working proper... just needs to wake up. the remote may be your problem.
God Bless Motorola For Giving Us Cable Boxes With No Buttons!
ok, does your remote have lights that flash when you hit buttons?
for example pushing volume lights up tv. if the cable light doesn't flash then it may need reprogrammed. if none of this applies to your remote... sorry
good luck
Sep 06, 2011 | Arris DCT700 DTV Receiver
Remote Codes for Motorola Cable Box DCT700/US
I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
If you take your hand or a thick book and sort of make a hood over the area of the sensor on the cable box and place the remote right up close to the sensor this will help let you know if the remote and the box are working with the code. Also might try turning off the TV or unplug the TV to test and make sure the remote will turn on the box.
Next thing after you determine this is how to block the interference and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
Good Luck ....
Jan 04, 2010 | One For All URC-9800 LCD Remote Control
Just want to know if i can get hd channels with a regular comcast motorola dct700 box, if so how? Also, what DVD player should I buy with this, as well as type of cables. TV just given to me, no remote,...
No HD channels on a DCT700, you have to have a HD capable box from comcast. Usually $8.95 a month for box rental. Don't know a lot about DVD players. If you get a comcast HD box, and have an HD TV, you should use an HDMI cable for best picture. Second choice is component cables. Those are the red, white and yellow or red, white yellow, blue and green cables.
Jan 03, 2010 | Haier HLH32ATBB 32 in. LCD HDTV
Through Amazon a Brookstone's "Jumbo Universal Remote" was delivered - there is no identification of who manufactures this remote. We need to have it control an AT&T-California cable box which was...
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (000, 031 & 032 for example)
3. Press and hold the corresponding button on the remote control
(CBL) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
2. Press and hold the corresponding button on the remote control
(SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode.
3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off.
5. When the device turns off, press any key to store the code.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I hope that helps.
Oct 26, 2009 | Televison & Video
Unicersal Remote code for Motorola cable box
I found this on another site: It works BUT you don't have all the functionality you would have with the cable remote (of course). If you want power on/off, vol up/down and channel change.. this is your fix.
Was this comment useful?
new Starbox("rating1496612", 0.0, {identity: 1496612, stars: 5, buttons: 5, max: 5, total: 0, onRate: saveVote});
  • Motorolla Comcast code Posted by whowlett5 on Dec 26th, 2008 at 12:40pm
    I got mine to work using the Code search method. The manual is incorrect though about using the code search: Instead of pressing Power repeatedly, you just press it once. It sequences through the codes. You then need to press Enter immediately when the comcast unit turns off.
  • May 23, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
    Remote Control Code for Motorola Cable Box
    I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at deannescollard@hotmail.com.
    Feb 22, 2008 | Motorola Mobility DRC800 Universal Remote...
    One For All URC-9800 LCD Remote Control Logo
    923 people viewed this question
    Top One For All Televison & Video Experts
    Joe Negus
    Joe Negus
    Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
