Kenmore 62622 Microwave Oven Logo
Posted on Feb 05, 2011
My Kenmore Microwave Model # 721 63683300, manufactured in December 2002, gives me an error code of "F-9" after running, or at least the fan runs, for 30 seconds. It also doesn't heat now. It was fine just an hour ago. The door latch seems to be fine - F9 fault codes of other manufactures seem to be related to the door latch. Any advice? [email protected]
5 Related Answers
Anonymous
  • 290 Answers
  • Posted on Oct 12, 2007
SOURCE: Kenmore built in microwave - f9 error
The model you have it listed under does not have any f codes. But I have run into this before so I think I know what you have. Double check the primary switch, this the top switch. You should have a white and/or yellow wire on the terminal marked NO and a blue and/or pink wire on the terminal marked C.
The F9 code is an inverter failure code. The tech manual gives next to nothing about trouble shooting for it. It basicly says replace inverter, if that doesn't fix the problem, replace control. However, since you also have no turntable operation this tells me there probably is a problem with the primary switch because the inverter and turntable both go to neutral through this switch and nothing else.  If you have a volt/ohm meter, you should have continuity through this switch when the door is closed and no continuity when it is open.
If you need more help, post back with the complete model number and I will try to walk you through it.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 20, 2009
SOURCE: f9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
Anonymous
  • Posted on Aug 07, 2009
SOURCE: I have an error code
I would like to repair the kenmore mocrowave myself, it has the error code f-9. Do I need to let the micrwave sit for a wile so the hi voltage can disipate from the inverter or magetron
Anonymous
  • Posted on Jan 19, 2010
SOURCE: My Kenmore Elite Microwave Model No. 721.64683300
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Jim Thurston
  • 672 Answers
  • Posted on Mar 04, 2010
SOURCE: Where can I get a user manual for a Goldstar
I have scanned this download with AVG and Ad-Aware and found it to be clean. This link will take you to a download of your owners manual. Take the free download and view or print. It is 30 pages. Good luck.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/MV-1501W-_E
F-9 code after running a shrt time
The F-9 error code indicates a defective control board, inverter or line voltage too high
if you have any further questions please message me back Thanks again Rick
5helpful
Microwave has an error code F9 after running for about 5 seconds
Some quotes from other forums, but note that you need to look up your model to verify part numbers:
"F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c."
"f9 model 721.63764300
Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, & testing.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
BUT once you have the part number from the Sears site, you can often get the parts cheaper
here.
6helpful
My Kenmore Elite Ultra Wave Technology microwave is displaying an F-9 error. What does that mean?
Here are a couple of quotes from another forum:
"Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
Note that part numbers mentioned may not for your model.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
BUT once you have the part number from the Sears parts site, you can often get the parts cheaper here
1helpful
F-9 pops up - microwave stops after 5 seconds. This is a Kenmore Elite Microwave, made in 2003. Model 721 63683300
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please don't forget to rate !
F-9 Error on Kenmore Ultrawave Microwave Model 721.64682300
From everything I have read it is a 1100w inverter, I am having the same problem.
1helpful
Runs okay, but makes loud noise when running
You dis-assemble the waveguide. Now try running it again, if noise still persists then the magnetron has failed. Get a new unit.
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
F7 Error code
Please reply back with your model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
2answers
F-9
Need to know the entire model # on the microwave.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
