The easiest way to update your console software is to connect to Xbox
LIVE. To update your console by using Xbox LIVE, all you need is an
Internet connection.
- Connect your Xbox 360 console to the Internet. To learn how, please see Connecting to Xbox LIVE.
- On the console, go to My Xbox, and then select System Settings.
- Select Network Settings.
- Select Wired Network or the name of your wireless network, if you are prompted to do so.
- Select Test Xbox LIVE Connection.
If you cannot connect
your Xbox 360 console to the Internet, you can copy the console update
from your computer to a USB flash drive and then install it on the
console.
Note: The USB flash drive must use the FAT32 file system.
- Plug your USB flash drive into a USB port on your computer.
- Download the update file.
- Click Save to save the console update .zip file on your computer.
- Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
- Copy the contents of the .zip file to the root directory of your flash drive.
- Unplug the USB flash drive from your computer.
- Plug the flash drive into a USB port on your Xbox 360 console.
- Restart the console.
- When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
You can update your Xbox
360 console software by downloading the update to your computer from
Xbox.com, burning the update to a CD or DVD, and then installing the
update on your console. Here's how:
- On your computer, download the update file.
- If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
- If you are using an earlier version of Microsoft Windows, you need
to use a special software program to unzip the file (for example,
WinZip).
- Insert a blank, writeable CD or DVD into your computer.
- Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
- Once the files have been burned to disc, remove that disc from your
computer and insert it into the disc drive on your Xbox 360 console.
