Honeywell QuietCare HCM-630 Humidifier Logo
Posted on Feb 04, 2011
Replaced filter but it's now stopped working. The orange light goes on but the fan won't start. Is there a reset button that needs to be tripped?
Humidifier light goes on. Fan does not work after cleaning it.
Humidifier Fan Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Humidifier/...---/Humidifier-fa...
Most Frequent Causes for Humidifier fan not working. For the most ... If the fan blade does not spin freely, replace the blower motor. If the fan blade spins freely, ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Aug 14, 2014 - Repair humidifier problems yourself with this expert, step-by-step ...6Lubricate the fan motor bearings with a couple of drops of light oil if the ...
Troubleshoot and Repair a furnace mounted Humidifier
www.instructables.com/.../Troubleshoot-and-Repair-a-furna...
InstructablesThis instructable will explain how to diagnose and, hopefully, repair a broken ... to flow through the water panel of the humidifier and the humidifier fan turns on. .... drain line was dry, GFI was not tripped, and the fan sounded like it was going so I ... Arduino · Intel IoT · Indoor Gardening · Lighting · Sewing · Parties · Star Wars.
My lennox furnace works just fine except that 25% of the time the fan keeps running when it shouldn't and blows cold air
You are using too restrictive of an air filter. If the codes you are getting off the lights says anything about a high limit this is the cause of your blower running all the time. Use a less restrictive filter or have your contractor install a media filter in the system. if you reset the furnace and it does not stop running the blower you have a stuck limit switch and may have to get another or call a service tech to reset it or replace.
Reset clean light
clean ligth its means still have dirt in filter or any,,,just clean and its will goes by its self,,
if not try to off an on again,but still the same,,its means the sensor need to replace,call for the service technician,dont waste time and money if you dont have any idea for the repair
4helpful
My Quietcare portable humidifier isn't working anymore after I cleaned the inside. The orange light is on but no fan is running. What is the problem and how do I fix it?
I was having the same issue. I noticed that when the main fan unit was removed, there was a small plastic piece that was sticking up from the base next to the filter, which has a female end on the fan unit. I played with this, and realized I could lift it up. Once I did this, I replaced the fan unit and it started working. I think this is the water level reader which, when all the way down, won't allow the fan to start since it thinks there is no water.
12helpful
2answers
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
Why do i have to go outside and manually hit the reset button on my heat pump to get the fan to come on?
that switch is a pressure switch that trips when the freon pressure get to high usally the problem is the coils on the unit are clogged water alone is usally not enough home depot sells a spray can of coil cleaner back were u would find the air filters depending your store follow directions CARFULLY and this sould sovle the problem.
Mar 15, 2010 • Humidifiers
Aprilair700
if it comes on when turned to RESET then its probably fine. The humidity may be higher than the highest setting on the stat. If you leave it on test reset it will not work .
2answers
BIONAIRE BCM630 TOWER HUMIDIFIER stopped working
If you would like to buy a new tower without a tank, I will be happy to sell mine.
6helpful
3answers
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
