If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise
Arcing is a sign that the Magnetron is shorting out. Make sure cover, usually plastic, is installed properly covering Magnetron port. It keeps food from entering port. This is a dangerous condition, replace unit.
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network:
HV Transformer
HV Diode
HV Capacitor
Magnetron Thermal Cut-Out
Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
