Question about Necchi 4575 Mechanical Sewing Machine
HOW DO I ADJUST THE PRESSURE FOOT FOR MORE PRESSURE...SEARS WILL SHOW SHOW ME ON THEIR SITE WHERE TO ADJUST THE PRESSURE, I NEED A PICTURE LIKE SEARS GIVES , SO I CAN ADJUST THE FOOT FOR MORE PRESSURE...WHERE ARE THE ON-LINE PICTURES FOR DOING THIS WITH MY NECCHI, SEARS GIVES PICTURES FOR THEIR MACHINES, YOU MUST ALSO HAVE ONLINE PICTURES,,,,THANKYOU
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
There should be a place to adjust the "feed dogs" on your machine. They should be able to be raised or lowered to give you proper to get the pressure of the pressure foot where you want it.
Posted on Aug 05, 2017
4 Suggested Answers
6ya staff
SOURCE:
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: where can I purchase Necchi Lydia 3 foot control
Contact this person and see if she can help you
dawn@sewingtime.co.nz
or
enquiries@sewingtime.co.nz
Or use their contact page
http://www.sewingtime.co.nz/contact.html
Then ask where you can get one.
The foot control you use should be readily available at any sewing machine parts supply source. There are models that range in USD from $35.00 to 69.00 for the replacement foot control.
I would look in the yellow pages under sewing machines and parts for a local replacement source not being concerned about brand name when it comes to a foot control other than like connections.
Thanks for using FixYa.
Kelly
Posted on Mar 20, 2010
SOURCE: How do you raise the
the presser foot lever is either on the left side of the machine where face plate is or at the back of the of the machine on the left
Posted on Nov 22, 2010
chris592
Chris DeWitt
  • 86 Answers
SOURCE: drop foot button on my necchi lycia 522 isn't
Sound like it may need service, it is dried out and sticking.
Posted on Jun 15, 2011
794 hobbylock. The pressure foot will not go up the lifter lever
screw on pressure foot near the lifter is slack. adjust and retighten.
Dec 31, 2017 | Sewing Machines
Pressure foot wont go fully down
The pressure foot is only made to push down on the material, not the feed dogs. If you put it too low it will destroy the feed dogs and the pressure foot as well as the material.
1. To adjust, lower the pressure of the pressure foot as much as you can.
2. Place a thick piece of material under the foot. Turn the hand wheel until the feed dogs are up.
3. The pressure foot rod has a screw that holds it into place. You will adjust the rod by moving it up and down until there is a small amount of pressure on the material. Tighten the screw and try your machine without a needle to see if the material will move. Now, try other thicknesses of material. The rod may need to be slightly adjusted a small amount to get it "just right".
4. PUT IN NEEDLE AND CHECK FOR ALIGNMENT TO THE HOLE. (DANGER IF NOT ALIGNED).
Aug 22, 2016 | Bernina Activa 130
How do I adjust the presser foot pressure on my Janome 7100QDC
your model doesn't have this feature Janome 7100QDC Computerized Sewing Machine , it it did, there would be a knob on the top left of the machine above the presser foot which you could screw up or down to increase or decrease the pressure. Its not a feature on many machines, the presser foot bar has a big spring internally which applies the pressure and this will just adjust to suit the fabric under the foot.
Mar 01, 2015 | Janome Sewing Machines
I need help with the outside walking foot on a singer211 it has to much pressure on it I need to know how to adjust.
I am NOT familiar with your Singer model 211, BUT.... Most machines [most brands too] have a knurlled screw knob on top which is attached to the long vertical shaft upon which the foot is mounted at the bottom.
"Normally," turning this screw clockwise tends to increase the foot pressure, while counterclockwise rotation tends to loosen the spring pressure on the foot!
Jan 09, 2015 | Sewing Machines
How to adjust pressure foot on singer model 14s654
Unscrew pressure foot and replace or use finer needles, and make sure they are not bent or that the zig zag is engaged
Dec 27, 2014 | Singer Sewing Machines
Bernina 1230 Is there a way to adjust the pressure on the presser foot?
Just checked on U-Tube there are several video's there for problems, otherwise there is a spring at the top of the needle shaft that can be loosened. Good Luck!
Sep 28, 2017 | Sewing Machines
How do you adjust pressure foot tension
you probably can't adjust the pressure on the foot, most models it is preset with no ability to adjust the pressure. Take a look at the top of the machine, left side above the needle area. If your machine has adjustable foot pressure, there will be a thumb screw of some sort on the top of the machine in this area, possible with a + and - symbol to indicate which way to turn to adjust the pressure.
I have owned Elnas, Janomes and Singers and only one of them had adjusted foot pressure.
Nov 02, 2012 | New Home HF-2022
I can't get the foot to lower and raise.
it sounds like it's out of time--here's how to fix it
to adjust the pressure on the presser bar and in turn the foot, locate the thumb
screw at the top of the machine
by rotating the thumb screw clockwise, you will increase the pressure, a counter
clockwise turn will decrease the pressure
the correct height of the pressure foot from the needle plate is 7mm.
to adjust this clearence loosen the screw & adjust the pressure bar through
the guide
secure the screw firmly when the correct adjustment is obtained
the distance between the presser bar lifting arm & the presser bar guide should
be 0.5mm ..( be sure the needle bar does not rotate left or right during the
adjustment process. the needle must be center of the presser foot & needle
plate hole,, if this is not centered re-adjust to the center of both needle foot
& needle plate hole.
Apr 07, 2012 | Sewing Machines
How do I adjust tension on my dogfeed?
You haven't said what make and model of machine you have.
Howver, pressure onto the feed dogs is usually controlled by adjusting the pressure foot pressure which is pushing the fabric down onto the feed dogs, you don't usually adjust the feed dogs themselves.
Pressure foot pressure is sometimes a dial or knob on top above the pressure foot area, if there isn't one visible on your machine, then it probably isn't a feature it has.
My Janome has knob on top that you can turn turn or up to tighten or loosen the pressure - I don't usually adjust it much though, only time might be if I'm sewing a couple of layers of vinyl or leather and having trouble getting it to feed.
Mar 25, 2011 | Sewing Machines
Necchi 4575 Mechanical Sewing Machine Logo
89 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
