Question about Samsung LN46A630 LCD TV
I just upgraded the firmware on my Samsung LA37 TV. Now the picture is really distorted - sort of psychedelic colours. Any ideas?
    New Friend:
  • 117 Answers
Dear user,
may be the firmware you upgraded is not compatible or suit able so kindly do old firmware of the lcd.
Posted on Feb 04, 2011
  • james662 Feb 04, 2011
    Thanks for the feedback.
    Samsung had pointed me to some software for a slightly different model, which initially caused the problem. So i changed back to correct software for my TV model (but a different country) but the colour distortion is still there.
  • Syed Salman Tahir Feb 07, 2011
    dear james,
    may be its your input fault .kindly check it with different input
6ya staff
SOURCE:
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Sony bravia problems....intermittent fault. Colour turns psychedelic. Looks like TV is "on acid"!! Sometimes TV can run normally for several hours before the colour fault occurs.
You have a defective T-Con board. The small board near the top center of tv. Can not give you the part number without knowing your TV model. Depending on model $50-120 for part.
Apr 16, 2014 | Televison & Video
Faulty picture which corrects itself after a few minutes.
Due to persistent on/off some components inside the TV might have become faulty, leaky. It can also be due to lose contacts. This might need attention by a qualified service technician.
Jul 24, 2012 | Televison & Video
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Pixelation at times colour distortion wavy lines any direction
what brand is this tv and what technology (plasma?)
To me this is plasma problem and maybe samsung brand. a posible adjustment can be done.
Apr 14, 2009 | Televison & Video
Is my picture tube going?
Hi there yes this is a common problem with old tube tv's and yes eventually stuff seems to break down there is not alot you can really do about it to be honest ...my suggestion is that this is lifes way of saying upgrade ...this tv has done well ....if your looking to upgrade i would suggest going to a Samsung LA26C450 as a replacement television or if you are not so much a fan then a KLV26BX300 as a new option ,
Cheers
Nov 04, 2008 | Samsung TXK2754 27" TV
Picture is psychedelic
the dmd board assy has failed possibly
Jun 12, 2008 | Samsung DLP HL-P5663W 56" TV
I have a rear projection samsung tv the picture is now colour distorted how can i fix it
need the model number and also can you explain what you mean with clor distorted? Is it appearing 3D? Let me know and post the model number and I will be able to help you.
May 18, 2008 | Samsung Televison & Video
Samsung LN-R328W TV Psychedelic picture
Multiple color lines around the image is most likely the convergence is off. from the menu find the option for convergence
follow the adjustment prompts. if that don't work the board has two IC's that are probably bad
May 02, 2008 | Televison & Video
Samsung LN46A630 LCD TV Logo
709 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
