Sony CRX320EE CD-RW/DVD-ROM Combo Drive Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony CD-RW CRX320EE has been disabled by windows xp service pack 2
Brian Sullivan
Level 3:
  • Sony Master 27,725 Answers
  • Posted on Feb 04, 2011
Brian Sullivan
Sony Master
Level 3:
Answers
27725
Questions
Helped
5664250
Points
79191
make sure that the cd-rw burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
2helpful
2answers
How to install cd-rw/crx320ee drive
installing CD drive no need installation driver, just install it like install Harddisk drive but you need to open the slot for your CD drive (dont forget to screw it). after u finish install it just reboot your computer, then the CD will automatically installed.
hope this useful.
2answers
My sony crx320ee cd-rw/dvd stop functioning normaly, cannot burn cd now. plz hlp!
i would recommend uninstalling the drivers completely and reinstalling them, however most drivers for cd roms cd/rw are preinstalled, and the only thing you can update is the firmware for the device itself. you may want to try unhooking the drive and rebooting the computer, then turning off the machine again, and reattach the drive, and restart. that might force it to re-configure and re-load the drivers
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Sony CD-RW CRX320EE is not ejecting...what to do..I think its jammed..
Take a paperclip, find a small hole in the front of the drive, and push the paperclip into the hole. The CD drive should eject. If it does not, it is time first of all for a new one anyway, but you may have to disassemble the drive to grab the CD.
4helpful
Sony CD-RW CRX320EE driver update
CD-Rom and DVD drives in itself do not need drivers in Windows, but the IDE/SATA controllers they are connected to do, so maybe that is what you are looking for?
You can use a driver update program or check the website of your motherboard manufacturer.
1helpful
2answers
My sony CRX320EE CD-RW/DVD-ROM COMBO Drive is not read a dvd
im having sony CRX320EE combo drive. it can read cd but cant read dvd. plz help
SONY CD-RW CRX320EE not functioning
sounds like your drive is bad.cd drives do go bad.and you can use nero essential to test the drive.you can also test the quality of disks and see the bad parts of them.depending how much you use them and how long you have it drives tend to go bad after 1000-2000 burns.if you got nymore question feel free to email me at [email protected]
My sony cd-rw crx320ee does not eject but it can read cds
When you say "not eject", I'm assuming you have tried ejecting from a physical button on the drive as well as selecting eject in Windows Explorer. If not, give it a try. If still a problem, note a small hole in the drive. Open a paper clip and gently place one end in the drive. The drive should open. Hope that helps.
My sony cd-rw crx320ee has been deleted, how can i recover it. my restore did not do it.
I can't Open/play any DVD from Combo drive & i can't write any cd from this. I have not any burning softwear.
Thanks
[email protected]
MY CRX320EE DOESN'T BURN DVD'S
This is because the model you mentioned is just a combo drive. It is not a dvd burner. You can watch dvd's with it but not burn them. The way manufacturers word the advertising leads some people to believe that they have a dvd and cd burner. All you have is a cd burner / dvd player. What you want is a dvd-rw / cd-rw drive. Sorry! I hope this helps.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
