Hi gee helen...
Go to the following website they carry parts for Farberware food processors.
They also have a toll free number to contact them: 1-800-675-9491
Please take time to rate me
"This is the direct link to the manual (in .pdf format) for the Sunbeam
Oskar Food Processor Model 14081, although the model number given on the
cover of this manual is #4817. I own and use this food processor (model
14081 as printed on the bottom of my machine) on a regular basis and
was also looking for the manual for it. After some very brief internet
searching, I found the manual for my machine online and the link I
provided will lead you directly to the manual for it as well."
This is the link to the manual Thanks for using FixYa
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
Remove the bottom plate, then use a flat blade, from the bottom edge of the top cover, pry out to release the tabs and the top cover will come off( there maybe 2 screws form the bottom to remove). Then you can replace the belt.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=540001 Generic problem for all Vacuums How do i replace the Posted by lmurray1 on Apr 23, 2008
How do i replace the fan blade assembly which are broken in my eureka model the boss thank you lorne Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 different models of the boss by Eureka – there is a standard old style upright that the belt that the belt would unscrew from the bottom of the motor and you would have to remove the top of the vacuum cover to remove the main motor and gasket assm, and then the fan has a reverse thread on the plastic fan and you would unscrew the fan after removing the belt pulley. Then you would screw on the new fan, belt pulley, replace the gasket and re-install the motor. If you have a new style with a side mount motor you would remove the top cover, the motor would be in there sideways, un-screw the motor, remove the silver tape around the fan housing and un-screw the fan housing – same as above un-screw the fan from the motor, there is a nut on the end of the fan holding that on – (remember, the fan has a reverse thread) re-install the fan. Then the fan housing, replace the silver tape, and then screw down the motor and replace the top cover, then you can test. As always free to contact your local vacuum dealer in your area in the yellow pages or contact your Eureka factory manufacturer listed below: http://www.eureka.comCustomer Service Phone Number 1-800-282-2886Hours of Operation Monday thru Friday 8:00 am to 7:30 pm CST Saturday and Sunday 10:00 am to 6:30 pm CST Thanks,Don – The Vac Man Go Ahead.Use Us.
I drp a screwdriver through one of holes in the blade; that "locks the blade" when the screwdriver comes up against the sole plate. Works great for tightening as well.
