You have to use the gas 75-25 for steel and cast iron 100% argon for welding alumanuan
sorry was trying to get to the spell check and hit the wrong button, ok back to what i was saying before i had a brain fart. you need the 75- 25 for welding steel and cast iron and you need 100% argon if you are going to weld aluminum. the gas provides a shield around the weld to keep impurities out this is why you are not getting any kind of penetration, the only way to mig weld with out gas is to use a flux core wire but it makes an ugly weld and is somewhat harder to work with. by the way if you can stick weld then you can mig weld it takes much more talent and control to stick weld.
Thanks or your input! Il get me some gas!
