Hello, Your printer makes a "grinding sound". This is usually due to two things:
1. A dirty printhead rail. It is either ink residue or dry. Try gently cleaning it with some water.
2. Paper pick up roller(s) not picking up. Clean them with a damp terry cloth towel or a multi-purpose cleaner.
If you have unable to fix it please contact me at 1800-204-4427. I can help you out.
Good luck!!
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
SOURCE: pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
SOURCE: trying to scan to email on Epson Artisan 800
If you are scanning wirelessly, you have to launch the epson scan software from your computer and scan to e-mail from there. You can scan using either professional or home mode.
Please take note that scanning from the printer only supports direct connection, which means you have to plug in the printer to your computer via a usb cable.
If you cannot launch epson scan, please let me know. And include the operating system that you are using too.
SOURCE: epson sx600fw displaying paperjam, No sign of any jam
did it happen after physically cleaning/flushing the head? I've had this a couple of times and clearly no jam. I removed the cartridges again, ran the rollers backwards and forwards a few times using the white gears, and powered up .... it recognises no cartridge present so went through the replacement again and the fault then clears. I think the s/w gets its knickers in a twist Printer is a heap of poo, and clearly designed to use asmuch ink as possible as it needs cleaning far too often. Wasted too much time on gettingit to print
SOURCE: Epson Artisan 710 won't print black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results..
Thank you!!
