Greetings,
if you have a filter on top there is usually two screws, remove these screws...use a putty knife to go under each corner and raise up. don't forget to unplug machine before you go this far....after top is raised. There are two screws in each inside corner of the front...remove those, disconnect any wiring on the door switch paying attention to where the wires go. Remove front and this gives you access to replace belt. the belt goes over the drum and through the belt pulley.. The belt pulley clips into a slot next to the front of the motor and lines up with the motor pulley. The belt goes thru the pulley and then around to the drive pulley on the motor... reinstall and all is well
