SOURCE: Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
SOURCE: hotpoint glass top stove
sound as if you only have 120 volts going to the range check the voltage
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
SOURCE: I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
