Sirius Satellite Radio Receiver Logo
Posted on Dec 13, 2017
I have a Sirius Starmate 3 Satellite Radio and the FM presets are full. I am in a part of the US where I have to set a new preset as the channels associated with the current presets are not available. How do I delete the current presets so that I can set up new ones as required? Thank you in advance. Dan Bresnahan
4 Related Answers
A
Anonymous
  • Posted on Jan 27, 2008
SOURCE: Sirius radio repair
[email protected]
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jun 09, 2008
SOURCE: Sat radio tuning question
You have to remove a memory setting in order to add a new one if you have six presets already set.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Oct 19, 2008
SOURCE: sirius satellite radio
Make sure the antenna has a good line of sight. Sirus works best when pointed in an Easterly direction. By default you should get channel 184 if there is no service activated on the radio.
All Sirius radios can be used for service only in the United States and Canada.
If you feel that the line of sight is ok and there are no obstructions from pointing your antenna either out of a window, on top of the car, or outside if it is used in a house, then try a different antenna. If you are using the smaller guage antenna wire, the connections can break inside during installation in a car from time to time.
If the radio is factory installed contact sirius at 1-888-539-7474 to see if they can see the radio on their end.
Anonymous
  • 1990 Answers
  • Posted on Jan 01, 2009
SOURCE: cannot set fm frequency on radio
Go through the Settings Menu on the Reciever until you see Frequency Select It and then turn the dial until it matches the same frequency that you are using on the Radio.
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Can i play mp3
Yes it does.....I have included a full list of specs for you for this model
  • DVD/CD player with navigation and built-in amplifier (15 watts RMS/50 peak x 4 channels, CEA-2006 compliant)
  • fits double-sized (4" tall) dash openings
  • motorized 6.5" LCD video screen with adjustable display angle and touchscreen controls
  • plays CDs, CD-Rs, CD-RWs, DVDs, DVD-R/RWs, and MP3 discs
  • GPS navigation (includes GPS antenna and map DVD-ROM)
  • City View mode - 3-D maps that render accurate representations of specific buildings in many cities
  • 6 million points of interest (hotels, restaurants, gas stations, etc.)
  • customizable route preferences
  • separate CD and DVD slots
  • five soundfields: cathedral, club, concert, live, theater
  • 9-band parametric EQ
  • 5 preset EQ curves
  • SIRIUS Satellite Radio-ready (you can add SIRIUS for under $100, plus subscription)
  • compatible with Eclipse HD Radioâ„¢ tuner
  • CD changer controls
  • audio/video input
  • rear-view camera input
  • audio/video output
  • 5-volt front, rear, and subwoofer preamp outputs
  • AM/FM tuner
  • 6 FM/6 AM presets
  • warranty: 1 year
Persistent occurance of "Sirius Seek List"
http://www.sirius.com/pdf/manuals/ST2-User-Guide.pdf
See page 24 on [or search for alert]. It's taken me a while to find this as I HAD the same problem
1helpful
Cannot set fm frequency on radio
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Setting preset stations
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
I have a starmate I think it is a older one and the sound doesnt work
My Sirius Starmate did the same thing last night. Playing with the line out got it to work for about one second.
3helpful
4answers
Sirius Starmate 4 - locks on the "Sirius: screen
with starmate 3 press at same time menu +memo+band with the radio on (with sirius screen only)
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
