If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
