Remove the fuel line from the carburetor and check for fuel flow from the line--it should release a thin stream of fuel. If nothing or just drips, something is plugging the line, shut-off valve, fuel filter, or tank fitting. If fuel does run out, then the carburetor is not taking in fuel. Remove the carburetor from the engine--make notes of where the springs and rods go that operate the throttle. Remove the float bowl and the float needle--make sure the line connection is not plugged going to the needle valve. Check the jets for any plugging. Use spray carburetor cleaner to clean the interior. Hope this helps!
