Sanyo  42 in. LCD TV Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the classification of simple machune
Anonymous
Level 2:
  • Expert 186 Answers
  • Posted on Feb 02, 2011
Anonymous
Expert
Level 2:
Answers
186
Questions
0
Helped
56150
Points
618
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
How do you fix error code U0151 in a 2014 Lancer?
i'd start by rechecking the "MDS on" install to make sure all connectors near where you were working are well seated. also recheck where the previous harness would contact. i find it really hard to beleive that the old harness was too short. improperly routed perhaps, but too short???
U0154 - LOST COMMUNICATION WITH OCM (occupant classification module)
  • When Monitored:
  • With the ignition on
  • IOD fuse installed
  • FCM is configured correctly
  • Set Condition: Bus messages not received from the Occupant Classification Module for approximately 2 to 5 seconds.
Possible Causes
CAN B BUS CIRCUITS OPEN OR SHORTED
DTCS RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES
FCM NOT CONFIGURED CORRECTLY
OCCUPANT CLASSIFICATION MODULE
OCCUPANT CLASSIFICATION MODULE POWER AND GROUND
MODULE THAT SET THIS DTC
OCM is located under passenger seat. make sure it's connector isn't loose.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
Machine says unable to calibrate, claims jammed paper in the doc feeder,
Check the sensor arms and make sure they move freely and are free of paper debris.
7helpful
2answers
Codes b1650 & b1785 on a 06 corolla came on what it posibly be?
B1650 Occupant classification System malfunction there are 4 possible trouble area No.2 floor wire,Front RH seat,center air bag assemble.
B 1785 Front occupant Classification Sensor LH collision Detection there is only one possible location to set this code Front seat LH
1helpful
2answers
I don't know what are the 3 classification of science?
The main three classifications of science( as per academic) are the following:
Physics
Chemistry
Biology( Botany and Zoology)
In common we have different classifications too..
computer science
social science.. etc..
1helpful
3answers
Intel dg 41 rq audio not working
Check the bios to see if its not Disabled
Check on the control panel, Device Manager and see if its installed if not Try this link
http://downloadcenter.intel.com/Default.aspx?lang=eng
if none of this help you can install External card
2answers
Need engine oil capacities for a 2.7L Hyundia
Lubricants and capacities
Engine oil options
Ambient temperature range Cold climate
Engine oil grade SAE 5W/30
Engine oil classification API/ACEA SJ/A2
Ambient temperature range Moderate climate
Engine oil grade SAE 10W/30
Ambient temperature range Moderate climate alternative
Engine oil grade SAE 10W/50
Ambient temperature range Hot climate
Engine oil grade SAE 10W/40
Engine with filter(s) litres 4,5
12helpful
2answers
DTC B1650 occupant classification system fault. 2007
If the vehicle has been in a rear end collision, expect this. If not, it just may need to have the Occ Class Sys reset. Toyota Dealer only.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
