In order for this to work properly it must be inserted between the last pre-amp stage and the power amp. Can you please update this with the mixer that you are using? With the make and model of the mixer, I can provide you with a connection description. Since each mixer will have different labeling and options, it is not possible for me to accurately describe the connections without hte make and model.
Thanks,
Dan
Not sure about that person's powered mixer, but I have the Behringer Feedback Destroyer and a Yamaha 312SC powered mixer, and so far I haven't had luck. It says I need to bring the return back to channels 5/6 or above, but I'm not sure what type of cable to use, and whether I then control the volume on the return channel or the source channel. Thanks!
how to hook up to external eq
