SOURCE: My Symbol P302FZY with RS-232 cable, not take the
this could be done by programming your scanner with correct parameters using manual or sofware utility, which I can provide for you. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
SOURCE: I HAVE WINDOWS 7.i cant
This download states that iti is compatible with Windows 7:
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7
Please give me a thumbs up if this was useful
SOURCE: I'm not getting communication from
To setup connection first find serial settings by:
Hold feed button whilst switching on label, will then print configuration and do a calibrate.
from the configuration print find settings for serial port format is something like " Serial port : 9600, N, 8, 1 "
set your PC to the same settings. This should work just fine.
SOURCE: I have Zebra LP2844 printer
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
SOURCE: Hello everybody. I can`t connect ZM600(zebra)
You must use a RS232 null modem cable or if you have a straight thru cable then get a null modem adapter to use with the straight thru cable.
