Acer Aspire One Netbook 8.9" Notebook Logo
Posted on Feb 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a problem with my acer aspire one.. i can only open it when it is plug in a charger but when i remove the charger it will turn off also.. what will i do? will i buy a new battery then?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
539
Points
24
Your battery's cell is dead, you must have purchase the new one.
Shahzad Waseem Akbar
Level 3:
  • Master 746 Answers
Master
Level 3:
Answers
746
Questions
0
Helped
272401
Points
2750
Hi, Ya Sure! the problem is with your battery and you should purchase a new battery ASAP to remove this problem.
Good Luck
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Accidentally plugged a AC/DC adapter into the computer and when we realized it was not the correct charger we tried the correct charger and it will not turn on at all. Did I ruin the Acer aspire one...
Probably you provided more than enough power to the computer and it some of the fuses or capacitors are burned out. But maybe this is not the case. Try to remove the battery, remove the hard drive, remove the RAM. Put these parts and your laptop on the table. Avoid placing them on the carpet or blanket as these wil produ2e static electricity that damages computer chips. Leave your laptop in this state for about 30min. Recone the parts, put the right charger and restart your computer
Acer aspire will not turn on or charge
Hello bperez28,
There are 3 possible reasons for that problem.
1. Battery is dead or is not seated properly. Try removing the battery from your laptop and then replace it back. If the battery is dead, it will not charge anymore. If it is still under warranty, ask for a replacement.
2. Charger is malfunctioning. Try to plug it into a different know working plug outlet. You might need to replace the charger with a new one.
3. Motherboard issue. Needs servicing.
You need trial and error to know exactly which of those is the reason why your Laptop is malfunctioning. Try a different charger/battery BEFORE buying one.
You can contact ACER directly from this link:
ACER SUPPORT
I hope this helped you out.
Thanks for using Fixya.
You can rate my answer if you appreciate the information I gave you.
Acer aspire one netbook ao 531 won't start up
Hi
Please remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON,
Please tell us your results
Good Luck
My acer 4720z will not turn on anymore and it been
Dear, Remove the battery and plug-in the power cable to the laptop and then start it. If it do start, then there is a problem with battery.
I m sure your laptop is under warranty. Please go to service center.
cheers
2helpful
ACER ASPIRE 5100 SERIES. WILL NOT DO ANYTHING. NOTHING WORKS, MOVES, MAKES ANY SOUNDS, BLANK DISPLAY. BATTERY LIGHT FLASHES WITH CHARGER PLUGGED IN. TRIED REMOVING RAM, AND HARD DRIVE. NOTHING.
the battery might be hosed up will it boot without the battery and just plugged to ac - if it wont boot from ac with the battery remover send it to acer
3answers
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
[email protected]
pls rate me 4 stars
1helpful
Acer aspire 5520 wont power up.. no charging light when connected to mains
Try another charger. If it turns on and chargers the unit you are currently using needs to be replaced. Do not leave your charger plugged in after charging your battery as this will shorten its life.
I’m happy to help further over the phone at https://www.6ya.com/expert/walter_628d4d23d01fb34d
1helpful
The prong that the battery charger plugs onto is loose/broken, how do i take the top off the laptop to do so?
Remove the keyboard first, there may be screws holding the case together under the keyboard.
Make sure you first remove all the battery and drives etc. there are usually screws in these areas that secure the case together.
The top and bottom parts of the case are held together by plastic clips. The best way to open the case is to start at an opening and gently spread apart the case until the clip releases and then continue along that edge and gradualy continue working along the other edges of the case.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
