Do you know anything about ECM five volt reference circuit's ?
DTC P0641: 5-Volt Reference 1 Circuit
The engine control module (ECM) has 3 internal 5-volt reference busses called 5-volt reference 1, 5-volt reference 2, and 5-volt reference 3. Each reference bus provides 5-volt reference circuits for more than one sensor. Therefore, a fault condition on one 5-volt reference circuit will affect the other 5-volt reference circuits connected to that reference bus. The ECM monitors the voltage on the 5-volt reference busses.
The 5-volt reference 1 bus provides 5 volts to the following sensors:
• The manifold absolute pressure (MAP) sensor
• The clutch apply sensor
• The fuel rail sensor
• The fuel tank pressure (FTP) sensor
• The intake air pressure and temperature sensor
The normal way is locate the battery, using a multi meter set to 20 volt DC check the volts across the terminals, if your battery is 12 volt the reading should be at least 12.5 and at most 13.5. If 6 volt the reading will be somewhere between 6.5 and 7.5 volts. Remove meter, start the engine, connect the meter back to the battery keep it set to DC and 20 volt. Note the meter reading at tick over and slowly increase the revs the voltage should rise to about 14.4 volts for a 12 volt system and maybe 8 volts for a 6 volt one. If volts to not rise then check regulator/rectifier, if OK check alternator.
Most automotive electronics work on a 12 Volt DC system. You must be using adapter capable of providing about 12 to 14 volts because car batteries provide 12 volts; but car alternators put out 13.8 volts. Do not attempt to connect to an adapter that put out AC voltage!
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU.
Before an explanation of how to do it you should keep in mind that this
is for a single receptacle only. If any other receptacles are on the
same circuit they will also be changed to 240 volt receptacles and if
you plug any 120 volt device into them, the 120 volt device will be
destroyed. That said OK, any 120 volt outlet can be changed to 240 volt
by removing the 120 volt circuits neutral, re identifying the white wire
with red or black phase tape and connecting it to a new 2 pole
15 amp breaker. The maximum that this circuit will now load up to is, on
#14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be
changed to a 15A - 240V receptacle so that 120 volt devices can not be
plugged into it. Never use 2 single pole breakers together because code
requires that on a fault trip both legs of the 240V circuit must be
disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that
convert foreign electricity to power devices from different parts of the
world. A step down voltage converter is a 220 to 110 volts converter. A
step up converter is a 110 volts to 220 volts converter. Our 2-way
converters are voltage transformers that convert power from both 220 to
110 volts and 110 to 220 volts. They also work with 100 volts, 110
volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage
converter / voltage transformer available in many different sizes
including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000
watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
According to Delonghi: "The outlet's power supply corresponds to the value indicated on the rating label on the back of the appliance." If that fails you can contact Delonghi Customer Service by email [email protected]
VERY unusual for a 6 volt system, they just do not work. Count the fill holes, usually there will be 6. Think 2 volts each. To be sure, hook up a volt meter and see, but it just HAS to be 12 volts. Been that way forever.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
You would not be able to modify your existing 110v power supply. You would have to have a 220v power supply. This would be nearly impossible to find tho as this machine is now more than 10 years old. I'll see if I can dig up a part number anyway just so you can do some searching.
A 12 volt battery is actually 13.2 volts fully charged. If you are reading 16 volts, you are probably getting extranious voltage from the system somewhere, especially if the vehicle is running when you check the voltage. The alternator will put out about 15-18 volts to charge the battery normally, and yours may put out 28-32 volts to charge them in series, but the batteries, when disconnected, should never read more than about 13.2 volts each. Typically, it will read about 12 1/2 volts when disconnected. COMPLETELY DISCONNECT BOTH OF THE BATTERIES. If you still read 16 volts when it is disconnected, you must have a bad meter because the battery can't produce that much voltage, no matter what. (Six 2.2 volt cells connected in series inside the case.) Put the meter on a known good battery on another car that is not running and see if you get the same reading. It sounds like the other battery is almost dead, regardless, and it sounds like your series/parallel switch may be malfunctioning. (That is the switch that puts the battery in series to run the 24 volt starter, then puts the batteries in parallel to run the remainder of the vehicle on 12 volts. This is all assuming that you have a diesel vehicle with a 24 volt starter and that is why you have two batteries.
transfarmer?
