Scholastic I Spy Junior Puppet PlayHouse for Windows, Mac Logo
Posted on Feb 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have windows 7 vista and its not letting me install the program.
montesmack
Level 2:
Novelist:
  • Expert 87 Answers
  • Posted on Feb 01, 2011
montesmack
Expert
Level 2:
Novelist:
Answers
87
Questions
0
Helped
41023
Points
255
Windows 7 or Vista
Right click installer and run as administrator.
Also you could try :
select "properties" at the bottom of the sub menu that pops up when you Right clicked
and from the window that comes up select the "compatibility" tab try XP Compatibility first.
Post your answers as a comment or reply and I'll be notified
Thank you
2answers
Ve an Asus K510J With Pre Installed Vista And I need to Clean Install Windows 7 On it Which is Not Proceeding and Says Files Missing
Sounds like you need to stick with Vista. Believe me, Windows 7 is just a tab bit better, but you'll have problems with it.
tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 • Computers & Internet
tip
How to install or run older programs on Windows 7
Since the release of Windows 7 many of my clients have been asking me about program compatibility and which programs will run on Microsoft's new operating system.
Their concerns were mainly because of Vista not running very well and they thought that they may be in for some of the same type of compatibility problems that Vista had.
Before Windows 7 was released to the public Microsoft said in a statement that "Any program that works on Windows Vista will certainly work on Windows 7"
Microsoft has certainly delivered their promise and much, much more!!!
I tested both the beta and the RC (release candidate) editions of Windows 7. In October of this year I was so impressed with Windows 7 I went out and bought Windows 7 Ultimate.
I was glad i did because Windows 7 is being welcomed with very open arms, people are upgrading so i need to know my may around the operating system.
At first i was weary about programs not installing because of compatibility problems but the procedure to either install a program or get it running when installed is relatively simple and is the same way that Vista uses.
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: Again, if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Sometimes you will get a message that says "This program may not have installed correctly, Reinstall using recommended settings and This program installed correctly"
It's up to you what you do from here, if the program works choose the latter. If your not too sure click on Reinstall using recommended settings"
So far (and i keep my fingers crossed) i have absolutely no problem in getting a program installed and running on Window 7. I will however provide more tips as and when they surface.
Please be aware that not all programs will work on Windows 7. These are programs which are mainly pre-XP like programs designed for Windows 2000, Windows 98/95.
on Dec 01, 2009 • Computers & Internet
2helpful
2answers
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
2helpful
Windows 7 Version does not recognize the Lexmark X5470 All-In-One Inkjet Printer and I do not have the disk to install and it is not listed on the updated list......
There is not Windows 7 Driver for this printer, you'll need to install the driver through "Compatibility Mode" using the Windows XP or Windows Vista driver.
Download windows vista driver here (Click Here), open the link, click "Download" button, wait for few seconds and save it. After the download's completed, right-click the downloaded file, select "Properties" then on the "Properties" window, click "Compatibility", select "Run this program in compatibility mode for :" select "Windows Vista.." from the available options. Select "Turn of Advanced text services for this program", click "Apply" then "Ok". You'll be able to install the driver on your Windows 7 computer.
If this isn't possible, first extract the downloaded file and do the same steps mentioned above to the "Setup.exe" file.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
5helpful
2answers
Does it work with windows 7?
That depends on which vesrion of windows 7 you have ?
The basic versions of windows 7 do not generally alow every program to be run that was designed for an earlier version of windows.
HOWEVER
I have found no problems running any application at all so far even if it was intended for an earlier version of windows.
The home premium version of win 7 is the lowest and may on rare occasion cough and spluter when running XP/vista apps.
In my tests sometimes the installation does fail but windows 7 then takes over and asks if I want to re-install using corrected setting.
If I let it do that then the installation has always worked.
Update to windows 7 on Gateway M-1624 Notebook with vista
You can upgrade to windows 7 from Vista is pretty straight forward. All you have to do is put Windows 7 CD in while running Vista and automatic startup should show you options to choose. There's some trouble with it sometimes for example, you can't upgrade a 32-bit version of Windows to a 64-bit version, or upgrade from a higher edition of Windows, such as Windows Vista Ultimate, to a lower edition, such asWindows 7 Home Premium. If this is the case, you'll need to use the Custom option during installation. Please remember that while Upgrading will keep all of your files and programs, custom installation will NOT. So you would need to back everything up before you start. Before you install Windows 7 make sure that all of programs that you need will work on it. For more information visit this microsoft website dedicated to upgrading to windows 7 >> http://windows.microsoft.com/en-US/windows7/help/upgrading-from-windows-vista-to-windows-7 Have a nice day and good luck.
1helpful
4answers
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
1helpful
Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
Top Scholastic Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Scholastic Video Game Console and Game Expert? Answer questions, earn points and help others
