Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
Posted on Feb 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
By the time it say 1c1c. will not come on when i hit bake
Mike Cairns
Level 3:
  • Jenn-Air Master 3,054 Answers
  • Posted on Oct 28, 2011
Mike Cairns
Jenn-Air Master
Level 3:
Answers
3054
Questions
0
Helped
850353
Points
6358
Hello, grammie
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
No manual. Hit the clean button and 15 minutes it caught on fire. Hit the cancel
It probably caught fire because to much crud was built up inside probably from not cleaning often enough. I assume there were not flames but just a lot of smoke, try again but watch it carefully. Some ovens are damaged by oven cleaner so I would get a manual first to be sure using that would be OM.
Here are some links that may help:
How to Clean Oven Naturally with Baking Soda Tutorial
How To Clean an Oven With Baking Soda Vinegar Cleaning Lessons from The...
Mar 02, 2015 • Ovens
I hit bake & it says off. I can't get the oven 2 say anything but off. Usually I hit "bake" & then up arrow 2 set temp but now as soon as I hit 'bake' or anything else it says '
Power reset it from the circuit breaker and if this does not help the control panel become more adverse to your selecting, then contact a professional. Sounds like the control board is going out.
The oven is 100 degrees colder then the read out
press bake and set to 550degrees. within 2 seconds press and hold the bake until 2 digits show on display, then release bake. the digits displayed is the amount of degrees the oven is off from original factory setting. If it reads 0, it is at original factory setting. you can now adjust by pressing the up button for a hotter oven, down for lower. it can only be done for 35 degrees. when done, hit clear/off. this will help to close the gap. if you are using an inexpensive thermometer, it can take a very long time for it to read the actual temp in the oven.
2answers
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 • Ovens
Oven igniter does not light unless hit
you can check you connections to see if loose wire nut.normaly people will say they hit the oven safty valve and gas will come out.the amp draw on that ignitor is as ive been taught 3.2 to 3.5 if low than that it will have a hard time opening the safty valve.ive sold and installed 100s of ignitors and a few valves.hope that helps.god bless tom
What is F2?
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board. F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Using the ovens
It's not dumb, it's the oven. You simply hit bake, temperature and then bake again. Of course you have to choose whether to bake or convection bake and you choose this when you hit the first and last bake command.
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
