SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
SOURCE: I have a Toro zero turn commercial 60
im no expert but had a similar problem with an old craftsman mower. the belt keeper which is an L shaped piece of hardware located at the back of the deck next to the idler pulley spindal. Also could be the deck is cockeyed and needs to be leveled or the wrong v-belt.
SOURCE: I have a toro lx426
Check this link and click on manuals at the bottom of the page under the Menu "Customer Care."
http://www.toro.com/home/mowers/recycler/index.html
Hopefully the manual at the least will verify the belt routing (diagram).
