SOURCE: cannot access pump in fisher & paykel washing machine
There has to be some access somewhere, behind?. Find it out, the problem is with your pump, unplug washer from the electric mains. Drain out your water by lowering the exit hose into bucket or ground drain, dismantle your pump to see what is clogging it. Before that see that the connections to the pump are tight; pull out and refit, it might sort out the problem. Or you have to change the pump. You can do all these yourself. Only note careful as to what came out how & how to refit.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
SOURCE: fisher paykel GW 11, no power to panel.
You will have to check the power from power supply to relay to control panel. You can check for voltage with multi-tester or voltmeter
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: service fault 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
SOURCE: Fisher and paykel GW611 excellence top loader wont
Check Out Of Balance switch This will prevent spinning and programme from advancing
