I have found the replacement charcoal filter for JVM1650BB, but it costs $59 online. Is there a comparable generic substitute at one of the more accessible "big box" stores, like Home Depot or Lowe's? Thanks, EK
**** a broke *** microwave!!!!!!! Shoot it with your gun!!!!!!! AHHHHHHHHHHHHHHHHH
You can save about $40 by going here...
www.microwaveglasstrays.com
If yours is part # WB2X9883, you can save about $10 on it here.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Thank you for such direct solutions!
