Microwave Ovens Logo
Posted on Jan 31, 2011
Hi, I just purchased a Popcorn Maker, Model # is PCD-01RED and im wondering if I can use oil in the machine or it doesn't recommend it.
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Feb 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
Helped
5585
Points
91
Just a few drops of oil will be ok or just a quarter spoon of butter or margarine. This is just to give the popcorn a flavour because you can equally pop with no oils or margarine.
Popcorn doesn't cook in my new combi oven. I'm on 1000W but the bag only half inflates after 3+ mins. Is it faulty or do I need to put the bag of popcorn on a plate? Has anyone else had this problem?
Definitely a Combi MICROWAVE oven?
Popcorn needs a certain amount of moisture in it to 'pop'. 1000 watts of microwave should work fine. Make your popcorn, put it in a bowl and eat the popped corn. Put the un-popped kernels in a pan with a little oil and see if they will pop. My theory is that the bag or the corn is old.
Make and model are always useful in such questions, then we can check specs.
1helpful
2answers
I just bought a 1.1 size microwave. I tried popping a full size bag of popcorn using 2 pushes of the popcorn setting. The bottom popcorn came out black. Any idea why?
The microwave burnt it. It will be a bit of trial and error with using your new microwave and will also depend (in this case) the brand of pop corn you've cooking. Check the recommendations on the pop corn packaging for time and heat range. Happy popping!
Popcorn popper 50030178 I found this old popper like my nanny used to use. But I don't know how much popcorn or oil to use can you help me. I have the measuring cup lid all the parts with it.
What type of popper is it? The 50030178 model isn't one I'm familiar with.
For most of the small air poppers, such as the Presto Air poppers, fill the measuring cup lid with popcorn so that the popcorn is level with the top of the cup. Add this amount of popcorn to the popper. On those units, there is a fill line inside the popping chamber. Do not fill past the line. For these air poppers, if you want to have butter or margarine on the popcorn, add 3 tablespoons of the extra to the lid after you replace it on the popper.
For the Hamilton Beach Hot Oil Poppers, the manual for the 73300 is available here: http://www.hamiltonbeach.com/use-and-care/use-and-care.php . Fill in the type of device and then the model. The amount of oil and popcorn will depend on how much you want to make. For a single serving, you need 2 T (tablespoons) of kernels and 1 - 1 1/2 t (teaspoon) of oil. For enough popcorn for a family, you should use 1/2 cup of kernels and 1T of oil. http://useandcares.hamiltonbeach.com/files/840190701.pdf has a full chart of the amounts on page 6.
I hope this helps. Please add a comment with the brand of popper and I'll check for a specific chart for that unit.
(It's been a while since I used the air popper that I used to have.)
I lost the instruction on how much oil and how much popcorn seed?
A Tablespoon of oil for 1/4 cup of popping corn should do the trick; this is what I use in the West Bend StirCrazy.
Most manufacturer's have instructions posted on their websites for their machines. With brand name and model number you should be able to find. Reply if you need help.
1helpful
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
3helpful
2answers
Need to clean air filter of burned popcorn smell
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
2helpful
No homegrown popcorn in a microwave? why?
Popcorn is a food that has a very low moisture content, and microwave ovens rely on moisture content (water molecules) in order to cook.
If there is not enough moisture to absorb the microwave energy, much of the the energy is reflected back to the magnetron and damage it.
This is also what damages a microwave when it is run empty.
A simple solution is to add about 1/2 to 1 cup of water in a microwave-safe container in the back corner of the oven and cook your popcorn a little longer.
You'll have to experiment a few times to get the combination right for your particular model.
But allow our microwave about 15 minutes or so for the magnetron to cool down between popcorn cooking sessions.
Also, I would suggest putting a paper plate upside-down on the turntable tray, then putting the popcorn container on top of that.
This does two things: It keeps the extremely hot popcorn off the tray, reducing the chances it will crack, plus it raises the popcorn up so it will heat more efficiently.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
