Blanco Sink Waste Strainer / Stopper BDSSSB Logo
A
Anonymous Posted on Jan 31, 2011
My strainer/stopper is stuck in kitchen sink drain. How to remove it?
Andrew Bugbee
Level 2:
Novelist:
Champion:
  • Expert 267 Answers
  • Posted on Jul 16, 2011
Andrew Bugbee
Expert
Level 2:
Novelist:
Champion:
Answers
267
Questions
Helped
168635
Points
403
If it's not visible from above then you must remove the trap j-bend. Go under the sink and put a big bowl or tray under the trap because when you remove the j-bend water will come out. You'll need a 12" grooved pliers, like channel locks, to get the nuts off. There are two of them. If the trap is old brass or chrome you may end up cracking the j-bend. If it's white or black plastic you can probably remove the nuts by hand. Look in the j and pull out your stopper. If it's visible from above a long pair of needle nose pliers would work best to remove the stopper.
1helpful
How do I remove the the cover of the drain to clean it
Are we talking about a sink drain or a floor drain? If its sink drain there is a stopper on the top and have to released from under the sink. The pipe underneath will have a 90 degree connection with a rod metal or plastic piece connected to the pull rod. Disconnect and it will free the stopper for cleaning. If a kitchen sink the piece is attached with plumbers puddy and a nut from under the sink. I would say its not worth cleaning or messing with it. If it's a floor drain. There is screws or a drop insert. Remove screws to release or simply lift out with a screw driver. Hope it helps.
tip
Simple Removal of Stuck Sink Stopper
I found an easy solution to removing a stuck stopper recently when I was fixing my kitchen sink and the stopper became vacuum-stuck. Instead of trying to pull on it (which will not work since the pressure is too great), or trying to release the vacuum by prying up an edge with a knife or other instrument (which would damage the stopper or sink), I used a (clean) toilet plunger to plunge the stopper out. Simply place the plunger squarely over the opening where the stopper is stuck and give it two good plunges. I got the stopper stuck several times while fixing the sink and this trick worked every time for getting the stopper unstuck. Make sure you are using a plunger that's cup-shaped (stands upright on its own), and not the kind that has a bulb at the end.
on Jun 28, 2014 • Home
The strainer/stopper is stuck in the kitchen sink the sink has a disposal unit attached. How do I remove it from the top
We just experienced the problem describe in this question. A dinner guest pushed the strainer stopper past the Blanco flange over the disposer and the stopper could not be removed by pulling straight up. The Blanco flange is difficult to remove so we knew that removing the flange would be a last ditch effort. I tried using several tools trying to deform the stopper enough to lift past the lower part of the flange but without success. While I was on the internet looking for a solution, my wife found the obvious answer. She pushed the stopper down into the disposer, rotated it 90 degrees. She then aligned the edges of the stopper with two of the small indents in the lower part of the flange. The stopper was then pulled up past the flange where only two points on the circumference of the stopper contacted the flange.
Kudos to her for this simple solution.
I need just the stopper for my double Elkay kitchen sink with LK99 stainless steel drain. How can I obtain just the stopper.
Boy this ( girl) anyway this this a hard one. Just call ELkay they have a service department where all they do is take can of you . Call them I dot have there 800 number but I bet its on there web site.
hey I am just an old plumber sitting up here late at night because of a bad knee.
So I hope I pointed you in the right area. Oh tey can have it to your home in 36 hours in the lower 48 . Great company and product, they know they charge more so they will give you V I P and you dont spend a dime
Good Luck Tom
I purchased a Blanco waste strainer #441099. It is brown plastic for a granite kitchen sink. My plumber could not use it. said it didn't have a ring that holds the disposal flange. There is a groove...
This strainer is not for a garbage disposal. The strainer for the garbage disposal comes with the disposal. If you bought two of these for the sink, then that's why you have one left. The disposal has its own.
We purchased a Silgranit sink and the recommended stopper-strainer (model no. 441098). Our plumber says that this unit is designed to fit through the sink bowl and attach to a waste disposal system (ie....
SILGRANIT II COORDINATED SINK WASTE DISPOSER STOPPER & STRAINER UNIT Fits disposer with 3-3/8" inside diameter only. It should just snap into the insinkerator sink flange.
Very slow drainage of a small bathroom sink. Liquid Plumber does not help
probably hair stuck in the drain. did you remove the stopper "pop up" if no hair or blockage there or in the trap, then its further down, you will need a small snake. 1/4 inch cable works well in bath and kitchen drains.
you can purchase one at home depot.
The sink drain leaks
Sounds like plumbers putty un drain flange to sink may need to be replaced or strainer may need to be tighten up a little to see if that stops the leak.
May 05, 2010 • Plumbing
My niece brush her teeth and left the toothpaste waste on my copper sink overnight - the next day everything obsorbed into the sink - how to fix it?
  • Polish with Bar Keepers Friend and fine steel wool. Use plenty of elbow grease. Keep the kettles extra bright by washing well with soap and water after polishing.
  • Dip half a lemon in kosher salt and rub well. Then polish with a soft cloth and beeswax for a deep, lasting copper shine.
  • Table salt and vinegar remove oxidation from copper.
  • To clean a copper kettle or boiler, you need to remove soap scum and hard water deposits as well as oxidation. Although a lightly oxidized copper piece can be cleaned with salt and lemon or vinegar, steel wool or a buffing wheel are required for heavy-duty copper cleaning.
  • Once your piece has a good shine, spray with a brightening product to maintain the clean, bright finish. Dust occasionally and wipe down with a cold, damp cloth.
hope i helped
Top Blanco Plumbing Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Steve Pack
Steve Pack
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
