Two methods:-
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
