My daughter turns her Nintendo DS Lite on and the top screen shows an SD/TF card error. She is unable to bring up any games. How can we fix this problem?
If you reformat the SD card you will not lose any of the software that is on the system. None of that data is stored into the SD card. The only thing that you can save to the SD card are pictures and you can back up you downloaded games onto it. Any software you have downloaded or came on the system will be completely unaffected if you reformat the SD card. Thanks for using FixYa!
I use to have similar problems with my DS Card :(. In the end, I end up buying a new one - I personally use http://www.NDS-Gear.com
Apparently, the Sd/tf message occurs when there is a problem with the connection between the micro SD and the DS Card or between the DS card and the DS. You can try giving your micro SD a good clean ( give it a good blow) and see if that makes any difference. Also, I heard that sticking some papers at the back of the DS Card works for some people. If nne of this work, you would robably want to buy a new one or try and get a repalcement from your seller.
just delete games and reload those cards do that all the time, make sure you drag the games into the themes folder.open system folder you will find the themes /games folder in there.enjoy
yes i know how to fix it, i have fixed many ds cards for other people check out my site http://jackdyeroms.synthasite.com like i said i have helped so many
to format the card is pretty simple really, all you have to do is:-
make sure your card is plugged in with the p.c same as you drag and drop go to my computer look for where your flash drive is dont click into it, right click it a little list will show go to format then click start (dont use quick format)
