Hello
Cjarboe,
I understand that your range is given you F2:E1 code this code states that the keypad cord is
unpluged. If you find that it is plug in and the error code comes up again you will need to replace the keypad. Here are the
dirrections to check/replace the keypad.
1. Unplug, shutoff power to the unit
2. Remove the knobs from the top of the control panel
3. Remove the
endcaps
4. Unscrew the control panel
5. Locate the serial cable
comming out of the keypad do the jiggle and make sure wire is tight on the keypad and control board.
6.
Reassable in the revearse
7. Check to see if error code displays again if it does you will need to replace the keypad.
This range has been
discontunuied by whirlpool and parts are hard to come by. Here is a link that I have found the keypad for $243.42 at the
followign link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=254959&diagram_id=28176301#d28176301
Thank you for choosing FIxYa.com
Justin
Gas stove wont' turn on
