Question about Homelite 'Yard Broom' Leaf Blower
The manual probably says 40:1 (3.2oz.oil to 1 gal gas) but if you use a good modern 2 cycle oil,50:1(2.6oz .oil to 1 gal gas) will suffice.
Posted on Feb 02, 2011
The manual for the Yard Broom II, models UT08012 and UT08512 says 50:1. It is troubling to me how many people on here (all of the answers I've read so far, actually) are just guessing at the answer to this. Getting the mixture right is important for the machine to run properly. Also, mixing too lean a mixture (too little oil to gas) would ruin the engine, possible in just one use. Using too heavy a mix (like the 40:1 or, unbelievably, the 32:1 I saw one person recommend) would likely only foul the spark plug. Still, It's aggrevation you just don't need. When in doubt, check the manufacturers website. They often have manuals available online. Homelites website can be found at www.homelite.com. It is odd that it doesn't have the mix ratio on the cap though. I had the same problem with one where I work.
The manual for the Homelite Yard Broom II, models UT08012 and UT08512 says 50:1. It is troubling to me how many people online (all the answers I have found to this question anywhere, actually) are just guessing at this. Getting the mixture right is important for the machine to run properly. Get the mixture to lean and it will ruin the engine, possible in just one use. Too heavy a mixture (like 40:1 or, worse still, the 32:1 I saw recommended on another Q&A site) will likely only foul the spark plug. Still, It is aggravation you just don't need. When in doubt, check the manufacturers website. They often have PDF versions of manuals available there. Homelite's can be found at www.homelite.com. It is odd though that the mixture is not stated on the gas cap. I had the same problem with one where I work.
May 20, 2011 | Homelite 'Yard Broom' Leaf Blower
May 05, 2011 | Homelite 'Yard Broom' Leaf Blower
Apr 03, 2011 | Homelite Blower Tubes Vac Attack Yard...
Feb 11, 2011 | Homelite 'Yard Broom' Leaf Blower
Jun 27, 2010 | Homelite 'Yard Broom' Leaf Blower
Jun 26, 2010 | Homelite 'Yard Broom' Leaf Blower
Mar 07, 2010 | Homelite 'Yard Broom' Leaf Blower
Nov 15, 2009 | Homelite 'Yard Broom' Leaf Blower
Nov 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Aug 31, 2008 | Garden
428 people viewed this question
