my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7 please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
The Touch Sensor AV Control Buttons above the Keyboard will not work if the Touchpad Driver in the Computer is not installed correctly. It is required to re-install the Touchpad Driver in the Computer to fix this issue.
You can download the Touchpad Driver from the below link.
update your Anti Virus first. then scan. maybe your computer has a virus. if it has no virus, check the battery. if the battery is good, then there is a problem on the motherboard.
hi there, it may be a virus or a problem with heat sensor. Many laptops have a fail safe built in to shut off the laptop when it registers the CPU being too hot. It prevents damage to the computer. If this is the case, you need to bring it to a computer shop to be repaired. If it is a virus, you may have to have a pro look at the computer.
Because of this platform does not have full teathered support for vista I bid you good luck on your find but do advise you check www.driverguide.com they have all drivers windows even the open source ones that you do not commonly find any other website.
A positve feedback is expected along with your 4 thumbs to the sky.
