I'm using the dulce gusto for the first time rinsing the machine as per instructions but no water is coming through filter.
Hi there I have a similar problem, when I turning on my krups fontana a weak noise coming from the machine and no water flow.Machine was`t on for 6-7 months. It sounds like a clogged water pump. Any idea how to clean it?
SOURCE: dolce gusto
Hi. I work at Nestle on the brand and it sounds like either a fuse issue or a clogged needle. Please call our consumer services number at 1-800-746-3391 for assistance. They are open Mon-Fri 8am to 8pm EST.
SOURCE: Dolce Gusto coffee machine hot water not flowing
use a solution of Bicarbonate of soda to clean scale from delivery pipe 1 tsp in 200ml
Please rate my help++++Thanks for using FIXYA
SOURCE: How do I descale a Krups Dolce Gusto machine?
Sorry about picture quality, fixya only let you upload small file sizes
SOURCE: no water coming out of
I am not sure of your particular machine yet I have repaired several other espresso machines and the majority of the times it is do to a clogged filter (usually a small metal perforated disk) Check to assure it is fully cleaned, for very difficult clogs soak or you can use a safety pin to clear the more difficult holes. Good Luck.
Douglas
