SOURCE: Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
SOURCE: Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
SOURCE: belkin n1 router - wireless light not on - laptop has limited connectivity
If could be that you were unable to reset the router properly. You have to make sure that the router is on while pressing and holding the reset button using a paper clip. the reset button is usually found at the back of the router, then you may have to reconfigure the settings again.
you can also manually access the router page for you to change the settings.
SOURCE: Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
SOURCE: Wireless Belkin N300 will not stay connected to my HP Pavilion
It might not work Because your laptop should XP service pack 2 Or above
You can try upgrading your operating system before throwing your router out of the door
