Washing Machines Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MHOW UNLOCK THE CHILD LOCK LG WASHING MACHINE MODEL WF-T7516HN
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Jan 30, 2011
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620343
Points
5972
The "CL" code is not an error! This means "Child Lock"!
To unlock the washing machine you will press and holding within 3-5 sec two button, marked "child lock if you have any further questions message me back or this solution does not work message me back the make and model of your machine and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
  • Anonymous May 01, 2012
    Hello i have problem in my washing machine thats it locked and it is flashes, so how can i fix it ? (Siemens WM16E160NN) plz i need solution and thanks .
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 01, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1008
Points
0
The child lock on my smart drum lg washing machine is on how doi turn it off please
To TURN OFF CHILD LOCK on your LG washer, press and hold the CHILD LOCK button for 3 to 5 seconds. The washer should now have CHILD LOCK mode DISABLED and all buttons will function properly.
PLEASE NOTE: ON other newer LG front load washing machines hold the PREWASH/CHILD LOCK button for 3 to 5 seconds to turn CHILD LOCK OFF.
M using LG's WF-T7516HN machine 6.5kg. it is showing error code "PE".What does it mean & what should i do now plz help.......
This is a fault with the pump( PE) and so it is possible that the pump is clogged or is inactive .
You will need to remove the pump and test to confirm or replace.,
check this link:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
I am getting error DE in my washing machine, need solution for this. Kindly give me the service error code for LG WF-T7516HN top loader
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
4helpful
2answers
LG "WM12336FD" washing machine is displaying ,CL,
I cannot find that model number in any of my LG data.
There is a button on the control panel that will say Child Lock. That button will have to pushed and held down until you hear the chime.
1helpful
Child lock button is stuck
hold the button in for about ten seconds this should unlock the panel
LG WF-764STP
Washer capacity- 7.2kg · 8 Washing Programmes · Child Lock · 53 cm Wide x 54 cm Deep x 85 cm High
Top Washing Machines Experts
john h
