SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
SOURCE: water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
SOURCE: FREEZER IS FORMING ICE IN VERY BOTTOM AND CAUSING DOOR TO STICK
first of all, defrost the freezer. after that swich off your refregerator for about 8hrs and place the thermostart point on 3...............now try it. i'm sure that your problem will be solved
SOURCE: the bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
