SOURCE: Please help!!
the only thing you can try is select settings then select profiles try selecting general this should be your default setting.
Try your phone and see if problem solved if not you will need to get the board cleaned and will need to send phone to repair shop to do sorry but this is all you can do
SOURCE: need help for hs-23 headset repair
In this middle section, the wires are as follows: MIC+: Yellow MIC-: Black L+: Blue L-: Copper/Grey Stripe? R+: Copper R-: Copper/Grey Stripe? (same as L-, they should be interchangeable...) Sirial?: Yellow/Orange Stripe Uout: Red GND: Green Hope this helps!
SOURCE: My planatronics bluetooth headset and
hi. at one point i purchased a moto-700 and it had the same exact problem, when i pulled the mike down it would work for about 10 seconds than disconnect. i pulled mike in and out about 20 times and finally it kicked in and now its my favorite tooth,probably not a solution just sharing my experiance with ya. good luck.
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
SOURCE: HOW TO REMOVE HEADSET ICON IN MY NOKIA N70
maybe you had your phone wet on the bottom part where the headset is to be plugged in. bring it to the nearest repair shop for the just to clean the metal contacts then, your icon will be gone
