White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps you out.
BuddyMc
SOURCE: Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
SOURCE: tv not responding to remote or buttons on tv
Try this website to get an original remote.1-800-Remotes Factory original.Still same prob. got a new remote,than the tv pannel control board it dead.
SOURCE: my flx-2611b elements tv stopped working today.
this a defective board, psu or inverter board, need to be checked. send to electronics repair store.
SOURCE: hi, i have a flx-2211b element electronics tv and
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
SOURCE: My element FLX 2210 has a problem. The tv turns
This part should fix your problem.
http://cgi.ebay.com/ELEMENT-FLX-2210-Power-BACK-pt-200-000-XXXXTLTX-AH-VLC-/120527410872?pt=LH_DefaultDomain_0&hash=item1c0ffe56b8
