First, carefully lay the face of the TV down on a soft surface with the stand protruding over the edge of the surface, then remove jack panel cover on the back of the TV to expose the 5 screws holding the base on. Remove those screws and slide the base away from the unit. These instructions are also found on page 5 of your owners manual.
Lay the TV face down on a flat, cushioned surface. (Use a blanket or quilt on a table with the stand hanging over the edge.). Remove the jack pack cover to expose the screws. Remove all 5 screws (3 above and two lower down). Then slide the pedestal away from the TV. Use care or you may damage the LCD panel.
The manual is available here: http://www.tacp.toshiba.com/tacpassets-images/models/52lx177/docs/52lx177_om_e.pdf and the directions and a picture are on page 5.
I hope this helps.
