If the car is overheating it could be due to a thermostat which is stuck in the closed position, a failed water pump or just a slack belt driving it. I think there will be a "little" tube carrying coolant from the engine to the coolant expansion tank, and if you run the engine with the filler cap removed you should see water coming through that pipe IF the rump is running. A failed water pump will not necessarily leak, it just won't pump the water round the engine.
Always take care when dealing with a pressurised cooling system on an overheating engine - the water may well be above boiling point.
If you run the engine without coolant the cylinder head may well warp and repair bill will be huge.
Hope this helps you a bit. D
Drove home ok, partner went to get in car, power low, turned key, no power, indicator lights inside flashing (not outside) can you help?
auto over heating pusing coolant back into water resivoir want to replace thermostat check for water leaks non found doesnt seems that there is water in the oil
Car overheating. Steam coming out of bonet. Have checked coolant and it's all ok.
